[GRASS-QA] GRASS QA: markus | ./grass6/imagery/i.class/histograms.c
	|no clones | 0 monsters | 2 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Sun Aug  5 06:49:39 EDT 2007
Hello markus,
ANALYSIS
imagery/i.class/histograms.c functions
histograms (Begins at: 26 Ends at: 232)
Complexity:   |      21 |     * |         |
ParamNBR:     |       9 |   *** | MONSTER |
CalledNBR:    |      51 |     * |         |
LOC:          |     207 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-08-05 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
