[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.li/r.li.daemon/list.c |no clones | 0 monsters | 0 warnings
Mon Aug 6 15:21:49 EDT 2007
Hello carlos,
ANALYSIS
raster/r.li/r.li.daemon/list.c functions
insertNode (Begins at: 27 Ends at: 45)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
removeNode (Begins at: 52 Ends at: 69)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
next (Begins at: 76 Ends at: 124)
Complexity:   |       8 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      49 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-08-06 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
