[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/parser.c |no clones | 1 monsters | 9 warnings
Tue Aug 7 03:36:39 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/parser.c functions
G_disable_interactive (Begins at: 162 Ends at: 183)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
G_define_flag (Begins at: 186 Ends at: 244)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      59 |       |      OK |
metrics are OK
G_define_option (Begins at: 247 Ends at: 329)
LOC:          |      83 |       |      OK |
metrics are OK
G_define_standard_option (Begins at: 332 Ends at: 603)
Complexity:   |      31 |    ** | Warning |
CalledNBR:    |      36 |     * |         |
LOC:          |     272 |   *** | MONSTER |
at least 2 values are close to an outlier please consider revising code
G_define_module (Begins at: 606 Ends at: 658)
CalledNBR:    |       1 |       |      OK |
LOC:          |      53 |       |      OK |
metrics are OK
G_parser (Begins at: 660 Ends at: 926)
Complexity:   |      37 |   *** | MONSTER |
CalledNBR:    |      74 |    ** | Warning |
LOC:          |     267 |    ** | Warning |
at least 3 values are close to an outlier please consider revising code
uses_new_gisprompt (Begins at: 929 Ends at: 979)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      51 |       |      OK |
metrics are OK
G_usage (Begins at: 981 Ends at: 1167)
Complexity:   |      33 |    ** | Warning |
CalledNBR:    |      53 |     * |         |
LOC:          |     187 |     * |         |
at least 1 values are close to an outlier please consider revising code
print_escaped_for_xml (Begins at: 1169 Ends at: 1185)
Complexity:   |       6 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
print_escaped_for_html (Begins at: 1192 Ends at: 1203)
Complexity:   |       7 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
G_usage_xml (Begins at: 1206 Ends at: 1420)
Complexity:   |      28 |    ** | Warning |
CalledNBR:    |      71 |    ** | Warning |
LOC:          |     215 |    ** | Warning |
G_usage_html (Begins at: 1422 Ends at: 1648)
Complexity:   |      42 |   *** | MONSTER |
CalledNBR:    |      85 |    ** | Warning |
LOC:          |     227 |    ** | Warning |
1 metric are OUT OF RANGE!
G_script (Begins at: 1650 Ends at: 1761)
Complexity:   |      22 |     * |         |
CalledNBR:    |      46 |     * |         |
LOC:          |     112 |       |      OK |
metrics are OK
generate_tcl (Begins at: 1763 Ends at: 1858)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      45 |     * |         |
LOC:          |      96 |       |      OK |
metrics are OK
G_gui_tcltk (Begins at: 1861 Ends at: 1890)
CalledNBR:    |       8 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
G_gui_wx (Begins at: 1893 Ends at: 1904)
LOC:          |      12 |       |      OK |
metrics are OK
G_gui (Begins at: 1907 Ends at: 1915)
Complexity:   |       2 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
G_tcltk (Begins at: 1918 Ends at: 1933)
LOC:          |      16 |       |      OK |
metrics are OK
show_options (Begins at: 1935 Ends at: 1965)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
show (Begins at: 1967 Ends at: 1980)
CalledNBR:    |       3 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
set_flag (Begins at: 1982 Ends at: 2009)
LOC:          |      28 |       |      OK |
metrics are OK
contains (Begins at: 2014 Ends at: 2023)
LOC:          |      10 |       |      OK |
metrics are OK
set_option (Begins at: 2025 Ends at: 2085)
CalledNBR:    |      13 |       |      OK |
LOC:          |      61 |       |      OK |
metrics are OK
check_opts (Begins at: 2087 Ends at: 2124)
LOC:          |      38 |       |      OK |
metrics are OK
check_an_opt (Begins at: 2126 Ends at: 2168)
ParamNBR:     |       4 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
check_int (Begins at: 2170 Ends at: 2236)
Complexity:   |      13 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      67 |       |      OK |
metrics are OK
check_double (Begins at: 2238 Ends at: 2278)
LOC:          |      41 |       |      OK |
metrics are OK
check_string (Begins at: 2280 Ends at: 2307)
Complexity:   |       8 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
check_required (Begins at: 2309 Ends at: 2332)
LOC:          |      24 |       |      OK |
metrics are OK
split_opts (Begins at: 2334 Ends at: 2397)
LOC:          |      64 |       |      OK |
metrics are OK
check_multiple_opts (Begins at: 2399 Ends at: 2437)
LOC:          |      39 |       |      OK |
metrics are OK
check_overwrite (Begins at: 2440 Ends at: 2496)
Complexity:   |      11 |       |      OK |
LOC:          |      57 |       |      OK |
metrics are OK
interactive (Begins at: 2498 Ends at: 2526)
LOC:          |      29 |       |      OK |
metrics are OK
interactive_flag (Begins at: 2528 Ends at: 2536)
LOC:          |       9 |       |      OK |
metrics are OK
interactive_option (Begins at: 2538 Ends at: 2628)
Complexity:   |      23 |     * |         |
CalledNBR:    |      41 |     * |         |
LOC:          |      91 |       |      OK |
metrics are OK
split_gisprompt (Begins at: 2630 Ends at: 2660)
LOC:          |      31 |       |      OK |
metrics are OK
gis_prompt (Begins at: 2662 Ends at: 2719)
CalledNBR:    |      20 |       |      OK |
LOC:          |      58 |       |      OK |
metrics are OK
G_recreate_command (Begins at: 2721 Ends at: 2823)
CalledNBR:    |      25 |       |      OK |
LOC:          |     103 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-08-07 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
