[GRASS-QA] GRASS QA: soeren | ./grass6/lib/gpde/N_upwind.c |no clones | 0 monsters | 0 warnings
Tue Aug 21 14:02:19 EDT 2007
Hello soeren,
ANALYSIS
lib/gpde/N_upwind.c functions
N_full_upwinding (Begins at: 33 Ends at: 61)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
N_exp_upwinding (Begins at: 63 Ends at: 77)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-08-21 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
