[GRASS-QA] GRASS QA: soeren | ./grass6/raster3d/r3.gwflow/main.c |no clones | 1 monsters | 0 warnings
Tue Aug 21 14:11:59 EDT 2007
Hello soeren,
ANALYSIS
raster3d/r3.gwflow/main.c functions
set_params (Begins at: 48 Ends at: 145)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      29 |       |      OK |
LOC:          |      98 |       |      OK |
metrics are OK
main (Begins at: 150 Ends at: 353)
Complexity:   |      25 |     * |         |
CalledNBR:    |      89 |   *** | MONSTER |
LOC:          |     204 |    ** | Warning |
1 metric are OUT OF RANGE!
write_result (Begins at: 360 Ends at: 425)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      20 |       |      OK |
LOC:          |      66 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-08-21 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
