[GRASS-QA] GRASS QA: carlos |
./grass6/raster/r.li/r.li.daemon/daemon.c |no clones | 2
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 22 12:14:37 EDT 2007
Hello carlos,
ANALYSIS
raster/r.li/r.li.daemon/daemon.c functions
calculateIndex (Begins at: 37 Ends at: 270)
Complexity: | 31 | ** | Warning |
ParamNBR: | 9 | *** | MONSTER |
CalledNBR: | 91 | *** | MONSTER |
LOC: | 234 | ** | Warning |
1 metric are OUT OF RANGE!
parseSetup (Begins at: 272 Ends at: 451)
Complexity: | 16 | * | |
ParamNBR: | 4 | | OK |
CalledNBR: | 106 | *** | MONSTER |
LOC: | 180 | * | |
disposeAreas (Begins at: 453 Ends at: 578)
Complexity: | 15 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 42 | * | |
LOC: | 126 | * | |
metrics are OK
next_Area (Begins at: 580 Ends at: 595)
Complexity: | 3 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 16 | | OK |
metrics are OK
print_Output (Begins at: 597 Ends at: 610)
ParamNBR: | 2 | | OK |
LOC: | 14 | | OK |
metrics are OK
error_Output (Begins at: 612 Ends at: 623)
CalledNBR: | 4 | | OK |
LOC: | 12 | | OK |
metrics are OK
raster_Output (Begins at: 625 Ends at: 636)
LOC: | 12 | | OK |
metrics are OK
write_raster (Begins at: 637 Ends at: 667)
Complexity: | 2 | | OK |
CalledNBR: | 15 | | OK |
LOC: | 31 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-08-22 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
