[GRASS-QA] GRASS QA: carlos | ./grass6/vector/v.out.svg/main.c |no
clones | 1 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 22 12:14:37 EDT 2007
Hello carlos,
ANALYSIS
vector/v.out.svg/main.c functions
main (Begins at: 41 Ends at: 307)
Complexity: | 24 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 119 | *** | MONSTER |
LOC: | 267 | ** | Warning |
1 metric are OUT OF RANGE!
mk_path (Begins at: 310 Ends at: 327)
Complexity: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 18 | | OK |
metrics are OK
mk_attribs (Begins at: 330 Ends at: 375)
Complexity: | 4 | | OK |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 20 | | OK |
LOC: | 46 | | OK |
at least 1 values are close to an outlier please consider revising code
print_escaped_for_xml (Begins at: 378 Ends at: 398)
Complexity: | 7 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 21 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-08-22 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
