[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.surf.fractal/process.c |no clones | 0 monsters | 0 warnings
Sun Aug 26 03:07:54 EDT 2007
Hello glynn,
ANALYSIS
raster/r.surf.fractal/process.c functions
process (Begins at: 13 Ends at: 55)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
data_reset (Begins at: 62 Ends at: 72)
CalledNBR:    |       0 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-08-26 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
