[GRASS-QA] GRASS QA: glynn |
./grass6/raster/r.surf.fractal/spec_syn.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Aug 26 03:07:54 EDT 2007
Hello glynn,
ANALYSIS
raster/r.surf.fractal/spec_syn.c functions
specsyn (Begins at: 21 Ends at: 154)
Complexity: | 6 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 28 | | OK |
LOC: | 134 | * | |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-08-26 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
