[GRASS-QA] GRASS QA: brad | ./grass6/db/drivers/sqlite/fetch.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 29 03:31:42 EDT 2007
Hello brad,
ANALYSIS
db/drivers/sqlite/fetch.c functions
db__driver_fetch (Begins at: 37 Ends at: 193)
Complexity: | 19 | * | |
ParamNBR: | 3 | | OK |
CalledNBR: | 37 | * | |
LOC: | 157 | * | |
metrics are OK
db__driver_get_num_rows (Begins at: 196 Ends at: 242)
Complexity: | 7 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 47 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-08-29 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
