[GRASS-QA] GRASS QA: brad | ./grass6/db/drivers/sqlite/index.c |no clones | 0 monsters | 0 warnings
Wed Aug 29 03:31:42 EDT 2007
Hello brad,
ANALYSIS
db/drivers/sqlite/index.c functions
db__driver_create_index (Begins at: 29 Ends at: 95)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      38 |     * |         |
LOC:          |      67 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-08-29 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
