[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.flow/calc.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Tue Feb 6 09:12:35 EST 2007
Hello markus,
ANALYSIS
raster/r.flow/calc.c functions
height_angle_bounding_box (Begins at: 85 Ends at: 138)
Complexity: | 5 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 30 | | OK |
LOC: | 54 | | OK |
metrics are OK
on_map (Begins at: 140 Ends at: 146)
Complexity: | 1 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 7 | | OK |
metrics are OK
add_to_line (Begins at: 153 Ends at: 161)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
LOC: | 9 | | OK |
metrics are OK
rectify (Begins at: 166 Ends at: 192)
Complexity: | 6 | | OK |
LOC: | 27 | | OK |
metrics are OK
next_point (Begins at: 194 Ends at: 283)
Complexity: | 9 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 17 | | OK |
LOC: | 90 | | OK |
metrics are OK
calculate (Begins at: 289 Ends at: 390)
Complexity: | 7 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 29 | | OK |
LOC: | 102 | | OK |
metrics are OK
main (Begins at: 392 Ends at: 427)
CalledNBR: | 19 | | OK |
LOC: | 36 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-02-06 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
