[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.flow/aspect.c |no clones | 0 monsters | 0 warnings
Wed Feb 7 03:53:17 EST 2007
Hello brad,
ANALYSIS
raster/r.flow/aspect.c functions
aspect_fly (Begins at: 32 Ends at: 53)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-02-07 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
