[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.flow/precomp.c |no clones | 1 monsters | 0 warnings
Wed Feb 7 03:53:18 EST 2007
Hello brad,
ANALYSIS
raster/r.flow/precomp.c functions
precompute_tangents (Begins at: 36 Ends at: 44)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
precompute_ew_dists (Begins at: 47 Ends at: 64)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
precompute_epsilons (Begins at: 67 Ends at: 100)
Complexity:   |       4 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
upslope_correction (Begins at: 103 Ends at: 122)
CalledNBR:    |      39 |     * |         |
LOC:          |      20 |       |      OK |
metrics are OK
interpolate_border (Begins at: 125 Ends at: 144)
CalledNBR:    |     144 |   *** | MONSTER |
LOC:          |      20 |       |      OK |
1 metric are OUT OF RANGE!
reflect_and_sentinel (Begins at: 147 Ends at: 161)
Complexity:   |       3 |       |      OK |
CalledNBR:    |      31 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
precompute_aspects (Begins at: 164 Ends at: 186)
CalledNBR:    |      17 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
precompute (Begins at: 189 Ends at: 219)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      20 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-02-07 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
