[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.flow/mem.c |no clones
| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Feb 7 03:53:18 EST 2007
Hello brad,
ANALYSIS
raster/r.flow/mem.c functions
put_row_seg (Begins at: 34 Ends at: 44)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 11 | | OK |
metrics are OK
initialize_globals (Begins at: 46 Ends at: 68)
Complexity: | 3 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 23 | | OK |
metrics are OK
allocate_heap (Begins at: 70 Ends at: 143)
Complexity: | 7 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 28 | | OK |
LOC: | 74 | | OK |
metrics are OK
deallocate_heap (Begins at: 145 Ends at: 176)
Complexity: | 6 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 32 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-02-07 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
