[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.flow/io.c |no clones
	| 0 monsters | 1 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Wed Feb  7 03:53:18 EST 2007
Hello brad,
ANALYSIS
raster/r.flow/io.c functions
tmp_name (Begins at: 40 Ends at: 53)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
parameter (Begins at: 58 Ends at: 74)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |       1 |       |      OK |
LOC:          |      17 |       |      OK |
at least 1 values are close to an outlier please consider revising code
flag (Begins at: 77 Ends at: 86)
Complexity:   |       1 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
parse_command_line (Begins at: 89 Ends at: 205)
Complexity:   |       7 |       |      OK |
CalledNBR:    |      47 |     * |         |
LOC:          |     117 |     * |         |
metrics are OK
open_existing_cell_file (Begins at: 208 Ends at: 220)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
read_input_files (Begins at: 223 Ends at: 282)
Complexity:   |      10 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |      28 |       |      OK |
LOC:          |      60 |       |      OK |
metrics are OK
open_segment_file (Begins at: 285 Ends at: 313)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
open_output_files (Begins at: 316 Ends at: 335)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
close_files (Begins at: 338 Ends at: 353)
CalledNBR:    |       5 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
write_density_file (Begins at: 356 Ends at: 394)
CalledNBR:    |      26 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-02-07 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
