[GRASS-QA] GRASS QA: paul | ./grass6/lib/proj/datum.c |no clones | 0 monsters | 0 warnings
Wed Feb 7 19:48:32 EST 2007
Hello paul,
ANALYSIS
lib/proj/datum.c functions
GPJ_get_datum_by_name (Begins at: 53 Ends at: 99)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      47 |       |      OK |
metrics are OK
GPJ_get_default_datum_params_by_name (Begins at: 101 Ends at: 152)
CalledNBR:    |       4 |       |      OK |
LOC:          |      52 |       |      OK |
metrics are OK
GPJ_get_datum_params (Begins at: 154 Ends at: 190)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      37 |       |      OK |
metrics are OK
GPJ__get_datum_params (Begins at: 192 Ends at: 255)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      20 |       |      OK |
LOC:          |      64 |       |      OK |
metrics are OK
GPJ_ask_datum_params (Begins at: 257 Ends at: 383)
Complexity:   |      14 |       |      OK |
CalledNBR:    |      44 |     * |         |
LOC:          |     127 |     * |         |
metrics are OK
get_datum_transform_by_name (Begins at: 385 Ends at: 471)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      23 |       |      OK |
LOC:          |      87 |       |      OK |
metrics are OK
read_datum_table (Begins at: 473 Ends at: 520)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      15 |       |      OK |
LOC:          |      48 |       |      OK |
metrics are OK
GPJ_free_datum (Begins at: 528 Ends at: 534)
LOC:          |       7 |       |      OK |
metrics are OK
free_datum_list (Begins at: 542 Ends at: 556)
Complexity:   |       2 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-02-07 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
