[GRASS-QA] GRASS QA: hamish | ./grass6/general/g.proj/main.c |no
	clones | 3 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Thu Feb  8 05:13:16 EST 2007
Hello hamish,
ANALYSIS
general/g.proj/main.c functions
main (Begins at: 29 Ends at: 484)
Complexity:   |      48 |   *** | MONSTER |
CalledNBR:    |     154 |   *** | MONSTER |
LOC:          |     456 |   *** | MONSTER |
3 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-02-08 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
