[GRASS-QA] GRASS QA: brad | ./grass6/vector/v.to.rast/vect2rast.c
|no clones | 0 monsters | 3 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Feb 8 11:55:50 EST 2007
Hello brad,
ANALYSIS
vector/v.to.rast/vect2rast.c functions
vect_to_rast (Begins at: 7 Ends at: 196)
Complexity: | 32 | ** | Warning |
ParamNBR: | 8 | ** | Warning |
CalledNBR: | 82 | ** | Warning |
LOC: | 190 | * | |
at least 3 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-02-08 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
