[GRASS-QA] GRASS QA: hamish | ./grass6/ps/ps.map/main.c |no clones
| 3 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Feb 9 03:49:19 EST 2007
Hello hamish,
ANALYSIS
ps/ps.map/main.c functions
main (Begins at: 70 Ends at: 730)
Complexity: | 96 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 232 | *** | MONSTER |
LOC: | 661 | *** | MONSTER |
3 metric are OUT OF RANGE!
usage (Begins at: 734 Ends at: 738)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 5 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-02-09 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
