[GRASS-QA] GRASS QA: glynn | ./grass6/lib/driver/Raster_RGB.c |no clones | 0 monsters | 0 warnings
Sun Feb 11 15:37:16 EST 2007
Hello glynn,
ANALYSIS
lib/driver/Raster_RGB.c functions
COM_RGB_set_colors (Begins at: 42 Ends at: 59)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
COM_RGB_raster (Begins at: 61 Ends at: 89)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       4 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-02-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
