[GRASS-QA] GRASS QA: glynn | ./grass6/lib/driver/color_support.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Feb 11 15:37:16 EST 2007
Hello glynn,
ANALYSIS
lib/driver/color_support.c functions
LIB_assign_fixed_color (Begins at: 34 Ends at: 41)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 8 | | OK |
metrics are OK
get_fixed_color (Begins at: 48 Ends at: 67)
Complexity: | 4 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 20 | | OK |
metrics are OK
get_fixed_color_array (Begins at: 69 Ends at: 85)
ParamNBR: | 3 | | OK |
LOC: | 17 | | OK |
metrics are OK
check_alloc_color (Begins at: 87 Ends at: 118)
Complexity: | 6 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 32 | | OK |
metrics are OK
LIB_assign_standard_color (Begins at: 125 Ends at: 129)
LOC: | 5 | | OK |
metrics are OK
get_standard_color (Begins at: 136 Ends at: 142)
LOC: | 7 | | OK |
metrics are OK
get_max_std_colors (Begins at: 148 Ends at: 151)
Complexity: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-02-11 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
