[GRASS-QA] GRASS QA: glynn | ./grass6/lib/driver/Color.c |no clones
| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Feb 11 15:37:16 EST 2007
Hello glynn,
ANALYSIS
lib/driver/Color.c functions
DRV_lookup_color (Begins at: 5 Ends at: 10)
Complexity: | 2 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 6 | | OK |
metrics are OK
DRV_color (Begins at: 12 Ends at: 16)
ParamNBR: | 1 | | OK |
LOC: | 5 | | OK |
metrics are OK
COM_Color (Begins at: 18 Ends at: 21)
Complexity: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 4 | | OK |
metrics are OK
COM_Color_RGB (Begins at: 23 Ends at: 26)
LOC: | 4 | | OK |
metrics are OK
COM_Standard_color (Begins at: 28 Ends at: 31)
LOC: | 4 | | OK |
metrics are OK
LIB_get_color_index (Begins at: 33 Ends at: 36)
LOC: | 4 | | OK |
metrics are OK
LIB_get_color_index_array (Begins at: 38 Ends at: 41)
LOC: | 4 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-02-11 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
