[GRASS-QA] GRASS QA: glynn | ./grass6/lib/pngdriver/Color_table.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Feb 11 15:47:42 EST 2007
Hello glynn,
ANALYSIS
lib/pngdriver/Color_table.c functions
set_color (Begins at: 11 Ends at: 17)
Complexity: | 1 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 7 | | OK |
metrics are OK
init_colors_rgb (Begins at: 19 Ends at: 22)
ParamNBR: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
init_colors_indexed (Begins at: 24 Ends at: 65)
Complexity: | 3 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 42 | | OK |
metrics are OK
init_color_table (Begins at: 67 Ends at: 85)
Complexity: | 2 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 19 | | OK |
metrics are OK
get_color_rgb (Begins at: 87 Ends at: 90)
ParamNBR: | 3 | | OK |
LOC: | 4 | | OK |
metrics are OK
get_color_indexed (Begins at: 92 Ends at: 98)
LOC: | 7 | | OK |
metrics are OK
PNG_lookup_color (Begins at: 100 Ends at: 105)
CalledNBR: | 2 | | OK |
LOC: | 6 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-02-11 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
