[GRASS-QA] GRASS QA: glynn | ./grass6/vector/v.digit/symb.c |1
clones ( main.c symb.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Feb 11 15:47:42 EST 2007
Hello glynn,
ANALYSIS
vector/v.digit/symb.c functions
get_symb_code (Begins at: 51 Ends at: 66)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 16 | | OK |
metrics are OK
get_symb_name (Begins at: 70 Ends at: 77)
Complexity: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 8 | | OK |
metrics are OK
symb_init (Begins at: 81 Ends at: 92)
CalledNBR: | 0 | | OK |
LOC: | 12 | | OK |
metrics are OK
symb_init_gui (Begins at: 96 Ends at: 105)
CalledNBR: | 3 | | OK |
LOC: | 10 | | OK |
metrics are OK
symb_set_driver_color (Begins at: 109 Ends at: 115)
LOC: | 7 | | OK |
metrics are OK
symb_line_from_map (Begins at: 121 Ends at: 154)
Complexity: | 12 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 34 | | OK |
metrics are OK
symb_lines_init (Begins at: 158 Ends at: 168)
CalledNBR: | 5 | | OK |
LOC: | 11 | | OK |
metrics are OK
symb_line_set_from_map (Begins at: 172 Ends at: 181)
LOC: | 10 | | OK |
metrics are OK
symb_updated_lines_set_from_map (Begins at: 185 Ends at: 196)
LOC: | 12 | | OK |
metrics are OK
symb_node_from_map (Begins at: 201 Ends at: 221)
Complexity: | 5 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 21 | | OK |
metrics are OK
symb_node_set_from_map (Begins at: 225 Ends at: 234)
LOC: | 10 | | OK |
metrics are OK
symb_nodes_init (Begins at: 238 Ends at: 248)
LOC: | 11 | | OK |
metrics are OK
symb_updated_nodes_set_from_map (Begins at: 252 Ends at: 262)
LOC: | 11 | | OK |
metrics are OK
updated_lines_and_nodes_erase_refresh_display (Begins at: 265 Ends at: 275)
LOC: | 11 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
In vector/v.digit/symb.c clones of symb_updated_nodes_set_from_map are:
vector/v.digit/display.c display_updated_lines
Threshold GRASS6 key metrics values at 2007-02-11 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
