[GRASS-QA] GRASS QA: glynn | ./grass6/display/d.vect/attr.c |no
clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Feb 11 16:58:04 EST 2007
Hello glynn,
ANALYSIS
display/d.vect/attr.c functions
attr (Begins at: 10 Ends at: 196)
Complexity: | 31 | ** | Warning |
ParamNBR: | 6 | * | |
CalledNBR: | 54 | * | |
LOC: | 187 | * | |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-02-11 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
