[GRASS-QA] GRASS QA: glynn | ./grass6/display/d.vect/label.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Feb 11 16:58:04 EST 2007
Hello glynn,
ANALYSIS
display/d.vect/label.c functions
label (Begins at: 8 Ends at: 151)
Complexity: | 25 | * | |
ParamNBR: | 6 | * | |
CalledNBR: | 31 | | OK |
LOC: | 144 | * | |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-02-11 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
