[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/color_str.c |no clones | 0 monsters | 0 warnings
Sun Feb 11 16:58:04 EST 2007
Hello glynn,
ANALYSIS
lib/gis/color_str.c functions
G_str_to_color (Begins at: 54 Ends at: 91)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      38 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-02-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
