[GRASS-QA] GRASS QA: glynn | ./grass6/lib/display/tran_colr.c |no clones | 0 monsters | 0 warnings
Sun Feb 11 16:58:04 EST 2007
Hello glynn,
ANALYSIS
lib/display/tran_colr.c functions
D_translate_color (Begins at: 25 Ends at: 52)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
D_translate_or_add_color (Begins at: 54 Ends at: 105)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      52 |       |      OK |
metrics are OK
D_allocate_color (Begins at: 107 Ends at: 123)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
D_parse_color (Begins at: 125 Ends at: 144)
Complexity:   |       3 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
D_raster_use_color (Begins at: 146 Ends at: 158)
CalledNBR:    |       2 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-02-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
