[GRASS-QA] GRASS QA: glynn | ./grass6/lib/raster/loc_io.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Feb 11 16:58:05 EST 2007
Hello glynn,
ANALYSIS
lib/raster/loc_io.c functions
LOC_init (Begins at: 22 Ends at: 56)
Complexity: | 4 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 20 | | OK |
LOC: | 35 | | OK |
metrics are OK
LOC_open_driver (Begins at: 58 Ends at: 101)
Complexity: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 44 | | OK |
metrics are OK
LOC__open_quiet (Begins at: 103 Ends at: 106)
CalledNBR: | 0 | | OK |
LOC: | 4 | | OK |
metrics are OK
LOC_stabilize (Begins at: 108 Ends at: 111)
CalledNBR: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
LOC_kill_driver (Begins at: 113 Ends at: 116)
LOC: | 4 | | OK |
metrics are OK
LOC_close_driver (Begins at: 118 Ends at: 123)
LOC: | 6 | | OK |
metrics are OK
LOC_release_driver (Begins at: 125 Ends at: 129)
CalledNBR: | 2 | | OK |
LOC: | 5 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-02-11 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
