[GRASS-QA] GRASS QA: martinl | ./grass6/general/manage/lib/do_remove.c |no clones | 0 monsters | 0 warnings
Sun Jan 21 06:42:47 EST 2007
Hello martinl,
ANALYSIS
general/manage/lib/do_remove.c functions
do_remove (Begins at: 12 Ends at: 95)
Complexity:   |      18 |     * |         |
CalledNBR:    |      35 |       |      OK |
LOC:          |      84 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-01-21 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
