[GRASS-QA] GRASS QA: martinl |
./grass6/general/manage/lib/do_remove.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Jan 21 06:42:47 EST 2007
Hello martinl,
ANALYSIS
general/manage/lib/do_remove.c functions
do_remove (Begins at: 12 Ends at: 95)
Complexity: | 18 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 35 | | OK |
LOC: | 84 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-01-21 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
