[GRASS-QA] GRASS QA: martinl |
./grass6/general/manage/lib/do_copy.c |no clones | 0 monsters
| 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Jan 21 08:43:45 EST 2007
Hello martinl,
ANALYSIS
general/manage/lib/do_copy.c functions
do_copy (Begins at: 23 Ends at: 109)
Complexity: | 6 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 25 | | OK |
LOC: | 87 | | OK |
metrics are OK
recursive_copy (Begins at: 112 Ends at: 186)
Complexity: | 16 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 22 | | OK |
LOC: | 75 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-01-21 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
