[GRASS-QA] GRASS QA: glynn | ./grass6/general/g.setproj/get_stp.c
|no clones | 1 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Jan 21 18:43:47 EST 2007
Hello glynn,
ANALYSIS
general/g.setproj/get_stp.c functions
get_stp_proj (Begins at: 7 Ends at: 41)
Complexity: | 8 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 18 | | OK |
LOC: | 35 | | OK |
metrics are OK
get_stp_code (Begins at: 43 Ends at: 73)
Complexity: | 7 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 31 | | OK |
metrics are OK
get_stp_num (Begins at: 79 Ends at: 136)
Complexity: | 9 | | OK |
LOC: | 58 | | OK |
metrics are OK
ask_fips (Begins at: 141 Ends at: 321)
Complexity: | 31 | ** | Warning |
ParamNBR: | 4 | | OK |
CalledNBR: | 88 | *** | MONSTER |
LOC: | 181 | * | |
1 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-01-21 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
