[GRASS-QA] GRASS QA: markus |
./grass6/vector/v.lrs/v.lrs.segment/main.c |1 clones ( main.c
)| 2 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Jul 5 10:16:24 EDT 2007
Hello markus,
ANALYSIS
vector/v.lrs/v.lrs.segment/main.c functions
main (Begins at: 43 Ends at: 331)
Complexity: | 36 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 130 | *** | MONSTER |
LOC: | 289 | *** | MONSTER |
2 metric are OUT OF RANGE!
find_line (Begins at: 337 Ends at: 354)
Complexity: | 3 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 18 | | OK |
metrics are OK
offset_pt_90 (Begins at: 360 Ends at: 364)
Complexity: | 1 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 5 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
find_line
In vector/v.lrs/v.lrs.segment/main.c clones of find_line are:
vector/v.segment/main.c find_line
Threshold GRASS6 key metrics values at 2007-07-05 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
