[GRASS-QA] GRASS QA: carlos | ./grass6/lib/gpde/N_parse_options.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Jul 5 12:02:36 EDT 2007
Hello carlos,
ANALYSIS
lib/gpde/N_parse_options.c functions
N_define_standard_option (Begins at: 42 Ends at: 110)
Complexity: | 8 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 69 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-07-05 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
