[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.gwflow/main.c |no clones | 0 monsters | 3 warnings
Thu Jul 5 12:02:37 EDT 2007
Hello carlos,
ANALYSIS
raster/r.gwflow/main.c functions
set_params (Begins at: 49 Ends at: 149)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      31 |       |      OK |
LOC:          |     101 |       |      OK |
metrics are OK
main (Begins at: 154 Ends at: 373)
Complexity:   |      24 |     * |         |
CalledNBR:    |      85 |    ** | Warning |
LOC:          |     220 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
copy_result (Begins at: 380 Ends at: 413)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       5 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
create_solve_les (Begins at: 418 Ends at: 466)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      21 |       |      OK |
LOC:          |      49 |       |      OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-07-05 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
