[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.in.ascii/main.c |no clones | 1 monsters | 0 warnings
Thu Jul 5 12:02:37 EDT 2007
Hello carlos,
ANALYSIS
raster/r.in.ascii/main.c functions
main (Begins at: 36 Ends at: 273)
Complexity:   |      26 |    ** | Warning |
CalledNBR:    |      97 |   *** | MONSTER |
LOC:          |     238 |    ** | Warning |
1 metric are OUT OF RANGE!
file_cpy (Begins at: 276 Ends at: 304)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-07-05 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
