[GRASS-QA] GRASS QA: carlos | ./grass6/display/d.vect/main.c |no clones | 3 monsters | 0 warnings
Wed Jul 11 18:32:45 EDT 2007
Hello carlos,
ANALYSIS
display/d.vect/main.c functions
icon_files (Begins at: 32 Ends at: 78)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      47 |       |      OK |
metrics are OK
main (Begins at: 81 Ends at: 710)
Complexity:   |      82 |   *** | MONSTER |
CalledNBR:    |     209 |   *** | MONSTER |
LOC:          |     630 |   *** | MONSTER |
3 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-07-11 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
