[GRASS-QA] GRASS QA: carlos | ./grass6/display/d.what.vect/main.c |no clones | 0 monsters | 0 warnings
Wed Jul 11 18:32:45 EDT 2007
Hello carlos,
ANALYSIS
display/d.what.vect/main.c functions
main (Begins at: 40 Ends at: 174)
Complexity:   |      15 |       |      OK |
CalledNBR:    |      52 |     * |         |
LOC:          |     135 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-07-11 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
