[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.extract/extract.c |no clones | 1 monsters | 1 warnings
Thu Jul 12 03:58:23 EDT 2007
Hello martinl,
ANALYSIS
vector/v.extract/extract.c functions
cmp (Begins at: 19 Ends at: 27)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
in_list (Begins at: 30 Ends at: 36)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
extract_cats (Begins at: 39 Ends at: 101)
Complexity:   |      13 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      14 |       |      OK |
LOC:          |      63 |       |      OK |
metrics are OK
areas_new_cats_match (Begins at: 104 Ends at: 145)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      11 |       |      OK |
LOC:          |      42 |       |      OK |
at least 1 values are close to an outlier please consider revising code
xtract_line (Begins at: 148 Ends at: 327)
Complexity:   |      32 |    ** | Warning |
ParamNBR:     |      10 |   *** | MONSTER |
CalledNBR:    |      37 |     * |         |
LOC:          |     180 |     * |         |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-07-12 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
