[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.extract/extract.c
|no clones | 1 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Jul 12 04:05:25 EDT 2007
Hello martinl,
ANALYSIS
vector/v.extract/extract.c functions
cmp (Begins at: 19 Ends at: 27)
Complexity: | 3 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 9 | | OK |
metrics are OK
in_list (Begins at: 30 Ends at: 36)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 7 | | OK |
metrics are OK
extract_cats (Begins at: 39 Ends at: 101)
Complexity: | 13 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 14 | | OK |
LOC: | 63 | | OK |
metrics are OK
areas_new_cats_match (Begins at: 104 Ends at: 145)
Complexity: | 8 | | OK |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 11 | | OK |
LOC: | 42 | | OK |
at least 1 values are close to an outlier please consider revising code
xtract_line (Begins at: 148 Ends at: 327)
Complexity: | 32 | ** | Warning |
ParamNBR: | 10 | *** | MONSTER |
CalledNBR: | 37 | * | |
LOC: | 180 | * | |
1 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-07-12 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
