[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.proj/main.c |1
clones ( main.c )| 2 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Jul 16 12:13:12 EDT 2007
Hello carlos,
ANALYSIS
raster/r.proj/main.c functions
main (Begins at: 69 Ends at: 437)
Complexity: | 27 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 160 | *** | MONSTER |
LOC: | 369 | *** | MONSTER |
2 metric are OUT OF RANGE!
make_ipol_list (Begins at: 439 Ends at: 458)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 20 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
make_ipol_list
In raster/r.proj/main.c clones of make_ipol_list are:
raster/r.proj.seg/main.c make_ipol_list
Threshold GRASS6 key metrics values at 2007-07-16 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
