[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.proj.seg/main.c |1 clones ( main.c main.c )| 2 monsters | 0 warnings
Mon Jul 16 12:13:12 EDT 2007
Hello carlos,
ANALYSIS
raster/r.proj.seg/main.c functions
main (Begins at: 69 Ends at: 445)
Complexity:   |      27 |    ** | Warning |
CalledNBR:    |     157 |   *** | MONSTER |
LOC:          |     377 |   *** | MONSTER |
2 metric are OUT OF RANGE!
make_ipol_list (Begins at: 447 Ends at: 466)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  make_ipol_list
In raster/r.proj.seg/main.c clones of  make_ipol_list are:
	raster/r.proj/main.c  make_ipol_list
Threshold GRASS6 key metrics values at 2007-07-16 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
