[GRASS-QA] GRASS QA: martinl | ./grass6/raster/r.mapcalc/map3.c |6
clones ( evaluate.c expression.c map3.c )| 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Jul 19 09:47:48 EDT 2007
Hello martinl,
ANALYSIS
raster/r.mapcalc/map3.c functions
setup_region (Begins at: 20 Ends at: 28)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 9 | | OK |
metrics are OK
handle_to_fd (Begins at: 62 Ends at: 65)
CalledNBR: | 0 | | OK |
LOC: | 4 | | OK |
metrics are OK
fd_to_handle (Begins at: 67 Ends at: 70)
LOC: | 4 | | OK |
metrics are OK
read_row (Begins at: 72 Ends at: 118)
Complexity: | 8 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 9 | | OK |
LOC: | 47 | | OK |
metrics are OK
write_row (Begins at: 120 Ends at: 169)
Complexity: | 11 | | OK |
CalledNBR: | 14 | | OK |
LOC: | 50 | | OK |
metrics are OK
compare_ints (Begins at: 173 Ends at: 176)
ParamNBR: | 2 | | OK |
LOC: | 4 | | OK |
metrics are OK
init_colors (Begins at: 178 Ends at: 190)
Complexity: | 6 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 13 | | OK |
metrics are OK
init_cats (Begins at: 192 Ends at: 203)
Complexity: | 3 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 12 | | OK |
metrics are OK
translate_from_colors (Begins at: 205 Ends at: 268)
CalledNBR: | 3 | | OK |
LOC: | 64 | | OK |
metrics are OK
translate_from_cats (Begins at: 270 Ends at: 330)
ParamNBR: | 4 | | OK |
LOC: | 61 | | OK |
metrics are OK
setup_map (Begins at: 332 Ends at: 334)
LOC: | 3 | | OK |
metrics are OK
read_map (Begins at: 336 Ends at: 373)
ParamNBR: | 6 | * | |
LOC: | 38 | | OK |
metrics are OK
close_map (Begins at: 375 Ends at: 396)
Complexity: | 5 | | OK |
LOC: | 22 | | OK |
metrics are OK
map_type (Begins at: 400 Ends at: 439)
Complexity: | 12 | | OK |
LOC: | 40 | | OK |
metrics are OK
open_map (Begins at: 441 Ends at: 530)
Complexity: | 25 | * | |
CalledNBR: | 16 | | OK |
LOC: | 90 | | OK |
metrics are OK
setup_maps (Begins at: 532 Ends at: 538)
CalledNBR: | 1 | | OK |
LOC: | 7 | | OK |
metrics are OK
get_map_row (Begins at: 540 Ends at: 572)
Complexity: | 13 | | OK |
ParamNBR: | 7 | ** | Warning |
LOC: | 33 | | OK |
at least 1 values are close to an outlier please consider revising code
close_maps (Begins at: 574 Ends at: 582)
LOC: | 9 | | OK |
metrics are OK
open_output_map (Begins at: 586 Ends at: 603)
Complexity: | 2 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 18 | | OK |
metrics are OK
put_map_row (Begins at: 605 Ends at: 610)
ParamNBR: | 3 | | OK |
LOC: | 6 | | OK |
metrics are OK
close_output_map (Begins at: 612 Ends at: 618)
LOC: | 7 | | OK |
metrics are OK
unopen_output_map (Begins at: 620 Ends at: 623)
LOC: | 4 | | OK |
metrics are OK
copy_cats (Begins at: 627 Ends at: 637)
LOC: | 11 | | OK |
metrics are OK
copy_colors (Begins at: 639 Ends at: 649)
LOC: | 11 | | OK |
metrics are OK
copy_history (Begins at: 651 Ends at: 653)
LOC: | 3 | | OK |
metrics are OK
create_history (Begins at: 655 Ends at: 657)
LOC: | 3 | | OK |
metrics are OK
Clone analysis:
This file has 6 potentially cloned functions:
copy_colors translate_from_cats copy_cats init_colors init_cats translate_from_colors
In raster/r.mapcalc/map3.c clones of init_cats are:
raster/r.mapcalc/map.c init_cats
In raster/r.mapcalc/map3.c clones of copy_cats are:
raster/r.mapcalc/map.c copy_cats
In raster/r.mapcalc/map3.c clones of init_colors are:
raster/r.mapcalc/map.c init_colors
In raster/r.mapcalc/map3.c clones of translate_from_cats are:
raster/r.mapcalc/map.c translate_from_cats
In raster/r.mapcalc/map3.c clones of copy_colors are:
raster/r.mapcalc/map.c copy_colors
In raster/r.mapcalc/map3.c clones of translate_from_colors are:
raster/r.mapcalc/map.c translate_from_colors
Threshold GRASS6 key metrics values at 2007-07-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
