[GRASS-QA] GRASS QA: martinl | ./grass6/raster/r.mapcalc/map.c |6 clones ( evaluate.c expression.c map3.c map.c )| 0 monsters | 1 warnings
Thu Jul 19 09:47:49 EDT 2007
Hello martinl,
ANALYSIS
raster/r.mapcalc/map.c functions
setup_region (Begins at: 20 Ends at: 27)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
compare_ints (Begins at: 66 Ends at: 69)
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
init_colors (Begins at: 71 Ends at: 83)
Complexity:   |       6 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
init_cats (Begins at: 85 Ends at: 96)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
translate_from_colors (Begins at: 98 Ends at: 161)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       5 |     * |         |
LOC:          |      64 |       |      OK |
metrics are OK
translate_from_cats (Begins at: 163 Ends at: 223)
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      61 |       |      OK |
metrics are OK
set_read_row_type (Begins at: 225 Ends at: 228)
LOC:          |       4 |       |      OK |
metrics are OK
read_row (Begins at: 230 Ends at: 236)
Complexity:   |       2 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
setup_map (Begins at: 238 Ends at: 254)
LOC:          |      17 |       |      OK |
metrics are OK
read_map (Begins at: 256 Ends at: 304)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      49 |       |      OK |
metrics are OK
close_map (Begins at: 306 Ends at: 333)
LOC:          |      28 |       |      OK |
metrics are OK
map_type (Begins at: 337 Ends at: 363)
LOC:          |      27 |       |      OK |
metrics are OK
open_map (Begins at: 365 Ends at: 450)
Complexity:   |      25 |     * |         |
CalledNBR:    |      15 |       |      OK |
LOC:          |      86 |       |      OK |
metrics are OK
setup_maps (Begins at: 452 Ends at: 458)
CalledNBR:    |       1 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
get_map_row (Begins at: 460 Ends at: 493)
Complexity:   |      13 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
LOC:          |      34 |       |      OK |
at least 1 values are close to an outlier please consider revising code
close_maps (Begins at: 495 Ends at: 503)
LOC:          |       9 |       |      OK |
metrics are OK
open_output_map (Begins at: 507 Ends at: 516)
LOC:          |      10 |       |      OK |
metrics are OK
put_map_row (Begins at: 518 Ends at: 522)
ParamNBR:     |       3 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
close_output_map (Begins at: 524 Ends at: 528)
LOC:          |       5 |       |      OK |
metrics are OK
unopen_output_map (Begins at: 530 Ends at: 533)
LOC:          |       4 |       |      OK |
metrics are OK
copy_cats (Begins at: 537 Ends at: 547)
LOC:          |      11 |       |      OK |
metrics are OK
copy_colors (Begins at: 549 Ends at: 559)
CalledNBR:    |       4 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
copy_history (Begins at: 561 Ends at: 570)
CalledNBR:    |       2 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
create_history (Begins at: 572 Ends at: 615)
Complexity:   |       4 |       |      OK |
LOC:          |      44 |       |      OK |
metrics are OK
Clone analysis:
This file has 6 potentially cloned functions:
  copy_colors  translate_from_cats  copy_cats  init_colors  init_cats  translate_from_colors
In raster/r.mapcalc/map.c clones of  init_cats are:
	raster/r.mapcalc/map3.c  init_cats
In raster/r.mapcalc/map.c clones of  copy_cats are:
	raster/r.mapcalc/map3.c  copy_cats
In raster/r.mapcalc/map.c clones of  init_colors are:
	raster/r.mapcalc/map3.c  init_colors
In raster/r.mapcalc/map.c clones of  translate_from_cats are:
	raster/r.mapcalc/map3.c  translate_from_cats
In raster/r.mapcalc/map.c clones of  copy_colors are:
	raster/r.mapcalc/map3.c  copy_colors
In raster/r.mapcalc/map.c clones of  translate_from_colors are:
	raster/r.mapcalc/map3.c  translate_from_colors
Threshold GRASS6 key metrics values at 2007-07-19 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
