[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.patch/main.c |no
clones | 3 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Jul 19 11:44:56 EDT 2007
Hello martinl,
ANALYSIS
vector/v.patch/main.c functions
main (Begins at: 45 Ends at: 372)
Complexity: | 40 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 135 | *** | MONSTER |
LOC: | 328 | *** | MONSTER |
3 metric are OUT OF RANGE!
copy_records (Begins at: 375 Ends at: 469)
Complexity: | 16 | * | |
ParamNBR: | 6 | * | |
CalledNBR: | 46 | * | |
LOC: | 95 | | OK |
metrics are OK
patch (Begins at: 471 Ends at: 510)
Complexity: | 5 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 40 | | OK |
metrics are OK
max_cat (Begins at: 512 Ends at: 531)
Complexity: | 3 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 20 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-07-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
