[GRASS-QA] GRASS QA: markus |
	./grass6/lib/rst/interp_float/init2d.c |no clones | 2
	monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Fri Jun  1 05:30:14 EDT 2007
Hello markus,
ANALYSIS
lib/rst/interp_float/init2d.c functions
IL_init_params_2d (Begins at: 18 Ends at: 112)
Complexity:   |       1 |       |      OK |
ParamNBR:     |      44 |   *** | MONSTER |
CalledNBR:    |       0 |       |      OK |
LOC:          |      95 |       |      OK |
1 metric are OUT OF RANGE!
IL_init_func_2d (Begins at: 114 Ends at: 135)
ParamNBR:     |      15 |   *** | MONSTER |
LOC:          |      22 |       |      OK |
Clone analysis:
Threshold GRASS6 key metrics values at 2007-06-01 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
