[GRASS-QA] GRASS QA: markus |
./grass6/lib/rst/interp_float/vinput2d.c |no clones | 5
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Jun 1 05:30:15 EDT 2007
Hello markus,
ANALYSIS
lib/rst/interp_float/vinput2d.c functions
IL_vector_input_data_2d (Begins at: 26 Ends at: 338)
Complexity: | 47 | *** | MONSTER |
ParamNBR: | 14 | *** | MONSTER |
CalledNBR: | 96 | *** | MONSTER |
LOC: | 313 | *** | MONSTER |
4 metric are OUT OF RANGE!
process_point (Begins at: 340 Ends at: 419)
Complexity: | 7 | | OK |
ParamNBR: | 15 | *** | MONSTER |
CalledNBR: | 13 | | OK |
LOC: | 80 | | OK |
1 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-06-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
