[GRASS-QA] GRASS QA: soeren | ./grass6/raster/r.gwflow/main.c |no
clones | 0 monsters | 3 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Jun 4 17:09:21 EDT 2007
Hello soeren,
ANALYSIS
raster/r.gwflow/main.c functions
set_params (Begins at: 49 Ends at: 156)
Complexity: | 1 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 31 | | OK |
LOC: | 108 | | OK |
metrics are OK
main (Begins at: 161 Ends at: 377)
Complexity: | 23 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 78 | ** | Warning |
LOC: | 217 | ** | Warning |
at least 2 values are close to an outlier please consider revising code
copy_result (Begins at: 384 Ends at: 417)
Complexity: | 3 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 5 | | OK |
LOC: | 34 | | OK |
metrics are OK
create_solve_les (Begins at: 422 Ends at: 468)
Complexity: | 10 | | OK |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 19 | | OK |
LOC: | 47 | | OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-06-04 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
